Amico - Solar Surgical Luminaire 2x4 LED Light
Solar Series
The Amico Surgical Luminaires use high quality LED’s that come in 80 and 90 CRI options. The lenses used are Symmetrical / Asymmetrical and designed to reduce glare. By using a one piece sealed housing and smooth doorframe & lens the luminaire is ideal for easy cleaning and infection control. The housing is designed for either flange or grid ceiling installations.
- Housing: 20-gauge CRS, hole-free seam welded construction
- Lenses: Once piece design; asymmetrical/symmetrical; see options for alternate lens
- Finish: White TGIC polyester powder coat. Salt spray test: 1,000 hours
- Optics: Symmetric/asymmetric reflectors diffused for glare free operation
- Drivers: High power factor electronic constant current, <10% THD, >0.97 pf @ 120 V (Class 2)
- Dimensions: 2' x 4' x 4" (fits into a standard ceiling grid layout)
- Voltage: 120 - 277 - 347 V
- Dimming: 0-10, 1-10 and PWM
- Color Quality: 80+ and 90+ CRI available
- Color Temperature: 3500K, 4000K, 5000K
- Estimated Life of LEDs: LM-80 tested LEDs with calculated L70 longevity over 130,000 hrs @ 55°C
- Listings: Luminaire is certified to UL standards by Intertek. Testing Laboratories for wet locations. UL certified IP65 per IEC 60598.
- Conducted emissions controlled as per MIL-STD-461G.
- Warranty: 5 years
