Datascope - Gas Module 3
Medical Gas Monitor
The Gas Module 3 incorporates improved Artema technology that enables respiratory gas analysis, displayed on our Passport 2®, Spectrum® and Spectrum OR™ lines of monitors - already standards of comprehensive vital signs monitoring excellence worldwide. The Gas Module 3 delivers state-of-the-art gas analysis capabilities: identification and measurement of inspired and expired O2, CO2, N2O, and any one of the following five anesthetic agents - Isoflurane, Sevoflurane, Desflurane, Halothane, and Enflurane. Providing impressive capabilities and highly reliable performance, this leading-edge breath-by-breath multi-gas analyzer was designed to meet the comprehensive anesthesia monitoring requirements of virtually every hospital - whatever its size, specialty, or patient base
2Replies10 years ago | Manual We are looking for a manual for a Datascope Gas Module 4100 plus multinex. Is this something you may have? Reply |
- Technology: NDIR type gas analyzer measuring at 3.9 – 12.8 μm with paramagnetic oxygen sensor. Pressure, temperature and full spectral interference correction.
- Operating modes: Startup; ISO accuracy; Full accuracy
- Measured gases: CO2, N2O, O2, HAL, ENF, ISO, SEV, DES
- Measured parameters: Momentary gas concentration; Inspired and expired concentrations of all gases; Breath rate
- Resolution: CO2 and agents: 0.01%; O2 and N2O: 0.1%
- Warm-up Time: ISO accuracy within 45 s, full accuracy within 10 min
- ISO Accuracy Specifications
- 200 mL/min sample flow rate for adult/pediatric water trap, and 120 mL/min with neonatal water trap.
- Uses a non-dispersive infrared analyzer measuring the absorption of the gas sample at seven infrared wavelengths.
- 2.5-second sampling delay
- Water trap that removes water and impurities from the patient sample.
- Analyzes patient sample at a fixed rate.
- Height: 3” (7.63 cm)
- Width: 11.9” (30.16 cm)
- Depth: 10.4” (26.35 cm)
- Weight: 6.2 lbs (2.8 kg)
