Bio-Rad Laboratories, Inc. - C1000 Touch Thermal Cycler
PCR Thermal Cycler
The C1000 Touch thermal cycler offers superior performance and a large color touch screen for easy programming. This fully modular platform is able to accommodate different throughput needs with easily interchangeable reaction modules that swap in seconds without tools. Each PCR module has a fully adjustable heated lid that supports a wide range of vessels and sealers, including low-profile and standard-height PCR plates.
FORUMSView All (8)
2Repliesa year ago | C1000 fails system start up The C1000 touch passed system start up tests. Ran the diagnostic test under administrator and passed. I accidentally started a second diagnostic test and was trying to cancel out and I clicked no to the lid not shutting. After the system would not pass system start up test. There was an error already present but not affecting function (x000D000D) slow cycling lid. Thanks for any insight.Reply |
0Replies2 years ago | Power block failure error 29 A e B Olá estou com um termociclador c1000 apresentando erro 29 POWER BLOCK FAILURE A e B. Testei transistores e capacitores dos circuitos das fontes e aparentam ok. Fiz a troca como sugerido em outros posts dos caps de 100uFx25V próximos ao U11 UC2844, sem resultado. Observei que o transistor Q9 IRFB3030 aquece bastante e ele não tem dissipador, mas esta ok nas medidas, e mais nenhum outro componente aquecendo Outra característica que esse defeito esta apresentando, ao ligar a chave on se escuta algumas oscilações. Alguém ja presenciou esse problema? Muito obrigado pela ajuda. Reply |
8Replies2 years ago | Block 5 sensor error x000D0015 I am trying to figure out where block 5 is. I pulled circuit boards and tested all temp sensors. Sensors tested good. Lid sensors and resistors tested in spec.. As I have no schematics (not available) I cannot trace any circuits easily to find TEM drivers and other possible suspect components. Any ideas would be welcome! Thanks, DanReply |
- A gradient-enabled 96-well fast module
- A gradient-enabled 96–deep well module
- A gradient-enabled dual 48/48-well fast module that allows 2 independently controlled protocols to be run side by side in a single bay
- A gradient-enabled 384-well module for high throughput
- 2 modules for real-time PCR detection
