Amico - Magna 50 LED
Magnifiers
The Magna 50 LED magnifier is the lighting solution for precise examination and is suitable for a number of fields of application. The Magna 50 LED magnifier light uses 48 innovative LEDs, providing critical added value compared to conventional fluorescent magnifiers. These LEDs provide four times more light per watt, considerably lowering energy consumption. The LEDs also offer a minimum of 50,000 hours of operating life at 100% brightness level – providing a magnifier light that is maintenance free for over six years running 24/7!
Connected Load
100-240V; 50/60 Hz
Fitted With
48 x Light-emitting diode light, neutral white, 3700-4000 K, color rendering index (CRI) = 90
Work Equipment
Electronic plug-in transformer
Mains Lead
Approx. 7.5 ft (2.3 m)
Luminaire Body Material
Aluminum/plastic
Tubular Sections Material
Tubular aluminum section anodized
Surface
Anodized
Weight (NET)
Approx. 2.7lbs (1.2kg)
Fastening
Table mount included for table mounted lights, rail mount included for rail mounted lights, wall mount included for wall mounted lights, floor stand included for floor stand light
Technology
Multi-stage switchable; continuously dimmable multifunctional switch
Usage
Multifunction switch
Lamp Cover
Acrylic clear
Class Of Protection
II
Color Luminaire Body
Black
Color Of Tubular Sections
Silver metallic
Lens Dimensions
ø 160 mm (6.3")
Lens Diopters
3.5
Add-On Lens
Not available
