Netech - DT-205L/DT-207L
by Netech
Digital laser tachometer.
The Laser Tachometer 200L is a battery-powered, microprocessor-controlled tachometer engineered for precise contact and non-contact rotational speed measurement. Designed for biomedical engineers and technical service professionals, this instrument ensures accurate RPM readings for a wide range of medical devices and rotating components.
In non-contact mode, the Laser Tachometer 200L utilizes a high-intensity laser beam to measure RPM by targeting a reflective tape on a shaft or any rotating mechanism. For contact measurement, the included 200L Adapter enables precise readings via a rubber tip cone attachment or 6" master linear wheel, offering flexibility for different testing setups.
Compact, reliable, and easy to operate, the Laser Tachometer 200L provides fast, non-invasive diagnostics for biomedical calibration, preventive maintenance, and equipment performance verification. (Generated by AI)
