Advanced Instruments - BR2
For Total Bilirubin and Direct Bilirubin Measurement.The Advanced Instruments Model BR2 Bilirubin STAT-Analyzer™ employs the method of Evelyn-Malloy, after Henry, to measure total bilirubin and direct bilirubin in neonatal samples. The BR2 determines bilirubin levels through spectrophotometric analysis.
1Reply12 years ago | Osmometer 3900 Heat transfer fluid pump blocked. Need solution. Reply |
- Identify hyperbilirubinema
- Chart the normal course of post-partum physiological jaundice
- Monitor those at high risk of kernicterus
- Determine the onset of normal hepatic bilirubin conjugating mechanism
Uses and Applications:
Height | 18 cm |
Length | 33 cm |
Weight | 4 kg |
Width | 28 cm |
Range: 0 to 30 mg/dL
Resolution: ±0.1 mg/dL
Test Time: Instantaneous for TOTAL Bilirubin, 2 minutes for DIRECT Bilirubin
