Verathon - GlideScope BFlex
GlideScope® BFlex™ is a single-use bronchoscope designed with exceptional image quality and maneuverability for difficult airways and bronchoscopy procedures.
BFlex with GlideScope Core 15
GlideScope® Core™ is compatible with GlideScope’s extensive portfolio of video laryngoscopes and BFlex single-use flexible bronchoscopes. Treat routine, difficult, and emergent airways quickly.
Single-use means easier access to bronchoscopes when you need them and faster setup so you can start turning over more cases in less time.
GlideScope BFlex delivers exceptional visualization of the airway with excellent image quality and clarity.
The BFlex design provides the perfect balance of strength and flexibility for optimal maneuverability.
- Magnetic Glidescope QuickConnect technology
- Centralized suction
- Convenient ET tube retainer
- Working channel
- Reinforced, steady insertion tube
- Visible measurement markers for positional accuracy and clinical reference
- Wide range of articulation
- Internal camera offers excellent image clarity
KEY SPECIFICATIONS | BFlex 3.8 | BFlex 5.0 | BFlex 5.8 |
Insertion tube outer diameter (mm) | 3.8 | 5.0 | 5.8 |
Working channel diameter (mm) | 1.2 | 2.2 | 3.0 |
Minimum endotracheal tube size (mm) | 5.0 | 6.0 | 7.0 |
Maximum accessory width (mm) | 1.0 | 2.0 | 2.6 |
Minimum DLT size | 35Fr | NA | NA |
