Amico - Powered Therapeutic Mattress
Support surface mattress.
With the option of air-filled, low-air-loss and alternating air mattresses, pressure relief can be achieved with the use of technology to create dynamic surfaces. Pressure ulcers result from prolonged pressure that cuts off the blood supply to the skin, causing the skin and other tissue to die. The damage may occur in as little as 12 hours and may go unnoticed until the skin begins to break down, days later.
- Vented cushions for low air loss therapy preventing moisture build-up
- Microclimate management increases air flow and circulation
- 16 cell overlay allows for even distribution of patient’s weight and maximizes pressure relief
- Anatomical uninterrupted pressure distribution
- Easy to set up and clean
- Lightweight design with handles allows for effortless transport and storage
- Lock-out key prevents tampering of patient settings and power switch
- Accommodates patient weight of up to 500 lbs (226.8 kg)
- Overlay Mattress: 80" x 36" x 5"
- Replacement Mattress: 80" x 36" x 8"
- Control Unit: 9.5" x 5" x 5"
