Amico - Hummingbird Laptop Powered Electric Lift
by Amico
Workstation on Wheels
Amico's Hummingbird mobile medical workstations are optimized for enhanced clinician experience, efficient administration, and improved patient outcomes. Ergonomic design with sit-to-stand, independent monitor height adjustment, and oversized castors for lightweight movement make the Hummingbird the ideal workstation on wheels for all medical facilities.
General Specifications
  • Materials of construction: Aluminum, ABS plastic
  • Warranty: 5 years (excluding batteries and power system)
  • Approved cleaning solution: explained in manual
Base Dimensions
  • Base (wheel to wheel):
    17.20" x 17.25" (43.68 x 43.81 cm)
  • Base (overall):
    20.307" x 20.232" (51.56 x 51.38 cm)
  • Base clearance from floor:
    1.62" (4.11 cm)
Weight
  • Electric lift carrying load: 100 lbs
  • Pneumatic lift carrying load: 35 lbs
  • Weight without equipment/Shipping Weight:
    • LCD non-powered (base model):
      75 lbs
    • Laptop non-powered (base model): 65 lbs
    • LCD powered (base model): 110 lbs
    • Laptop powered (base model): 100 lbs
