Workstation on Wheels
Amico's Hummingbird mobile medical workstations are optimized for enhanced clinician experience, efficient administration, and improved patient outcomes. Ergonomic design with sit-to-stand, independent monitor height adjustment, and oversized castors for lightweight movement make the Hummingbird the ideal workstation on wheels for all medical facilities.
Base Dimensions
- Base (wheel to wheel):
17.20" x 17.25" (43.68 x 43.81 cm) - Base (overall):
20.307" x 20.232" (51.56 x 51.38 cm) - Base clearance from floor:
1.62" (4.11 cm)
Height Adjustments
- Height adjustment (column):
13" (33 cm) - Height adjustment (LCD post): 6" (15.24 cm)
- Height adjustment (ergonomic keyboard): 7.5" (19 cm)
Height Dimensions
- Lowest column position: Add 4"
(10.16 cm) to all dimensions
if needing 8 bin SmartDrawers- Floor to top of worksurface
(in lowest column position):
35.127" (89.2 cm) - Floor to keyboard: 28.627" / 27.127" (72.69 / 68.88 cm)
- Top of keyboard to top of worksurface (sliding/ergonomic): 6.5" / 8"
(16.51 / 20.32 cm) - Worktop to top of LCD (assuming a 15" H LCD mounted in top position): 23.053" (58.54 cm)
- Overall height of cart (in lowest column position, highest post position and assuming 15" H LCD): 58.18" (147.77 cm)
Worktop Dimensions
- Worktop excluding handles (total worktop space): 16.755" x 19.847"
(42.54 x 50.39 cm) - Worktop including handles:
21.819" x 21.766" (55.42 x 55.27 cm) - Worktop spill guard area/volume:
10.17" x 19.947" x 0.04"/8 fl. oz.
(25.83 x 50.64 x 0.10 cm) - Worktop with keyboard extended:
- Ergonomic style keyboard (cart length changes): 10.546" (26.77 cm)
- Standard slide keyboard style (cart length changes): 6.875" (17.45 cm)
- Front of LCD to front of worktop (assuming a 2" thick LCD): 10.2"
(25.9 cm) - Front of LCD to fully extended keyboard (assuming a 2" thick LCD) sliding/ergonomic: 21.844" / 25.219"
(55.47 / 64.06 cm) - Inside worktop height PC compartment: 2.6" (6.6 cm)
- Inside worktop: 9.053" x 14.928"
(23 x 37.89 cm)
