Amico - Condor Adjustable Height Channel
Computer Mounting
Tight on space? That doesn't mean you need to sacrifice comfort while you chart. The Condor IT Station is uniquely designed to stay tucked away while offering you all of the ergonomic features you need to work happy. The Condor is perfect for hallways, patient rooms, and areas with very limited space. And because we’re all built differently, the Condor IT Station is constructed to be adjustable for all sizes. Adjust the height of the keyboard and screen together or individually tilt the keyboard, adjust the screen, and personalize your setup in seconds.
General Features
Patented counterbalance mechanism allows for a 20 lb (9.1 kg) range, ideal for needs of changing technology
- 17" (43.2 cm) overall height adjustment range provides sit to stand capabilities and can accommodate users of any height
- This mounting system is ideal for Electronic Medical Records (EMR) and folds back to within 10" (25.4 cm) from the wall (ultra flush hallway application model also available)
- Intelligent cable management system hides cables for an organized workspace
- Articulating arms allow caregivers to chart while maintaining eye contact with patients
- This Condor Patient monitor mounts has ergonomically friendly negative tilt keyboard tray
- Sealed keyboard tray for infection control
- Optional secondary work surface for clinicians
- CPU mounts available in various sizes
- Height locking knob reduces drift when in use
- Includes both 75/100mm VESA plates
- RFID upgrade available
