Aloka - ProSound Alpha 5
The ProSound Alpha 5 is Aloka's latest advance in digital diagnostic ultrasound for the operating room.Aloka's ProSound technology transmits and receives noise-free signals providing diagnostic information in a pure sound field. Aloka's advanced microcircuit technology provides for large-scale integration of the electronic circuit allowing for the creation of a high-density digital front-end. The resulting crisp and clear image contributes to more efficient and accurate examinations.
Aloka’s surgical HST transducers suppress side lobe artifacts three-dimensionally due to high-density transducer element fabrication and beam management in the elevation direction. This allows the fundamental ultrasound beam to be sharper and closer to the ideal beam shape than with conventional transducers. The result is higher resolution images with substantially less artifact.
Aloka’s high density digital front end allows a wider dynamic range for superior contrast resolution. With a 12 bit digital beamformer ultrasound images are inherently sharper and more detailed. Five ultrasound transmission beams per piezoelectric crystal combine to display truer, less interpolated, more complete image of the desired anatomical structure. The individual views are automatically combined, then artifact is automatically subtracted and real structures enhanced.
FORUMSView All (29)
0Replies3 years ago | certificate EMC? Hello, i need the certificate of electromagnetic compatibility from this device , where can i find it? thank you!Reply |
1Reply3 years ago | Software image harddisk Hello, please i need Software image harddiskReply |
0Replies3 years ago | Monitor Video Signal Hello. The monitor of this system is damaged. We would like to replace it but may be we need to adapt the video signal connector. Someone has an schematic to see how is the output video signal monitor configured. Thank you.Reply |
- Pure Sound Transmission – superior penetration and exceptional resolution
- Pixel Focus – Enables uniform beam characteristics from near to far fields
- Quint Frequency Imaging – All probes can be adjusted up to five different frequencies
- Dual Dynamic Display – Simultaneous real-time display of B and B/Flow Mode images
- Microspatial Compounding (for a more densely rich image)
- Pixel-Focus (for sharp detail in both near and far fields)
- iDMS (for hassle free image storage and retrieval).
- Alpha 5 is also designed to work with Aloka's wide variety of surgical specialty transducers.
Cart Based | 1 |
Clinical Applications | Colorectal |
