Amico - AHM Monitor Arms (Adjustable Height)
by Amico
Patient Monitor Mounts
AHM (Adjustable Height) Monitor Arms feature 120° of height adjustability and 180° side to side motion so that you can easily adjust the position of your attached monitor. The Adjustable Height Monitor Arms can also be locked in any position to maintain the desired height adjustment. The AHM can be mounted directly to any equipment rail or wall channel. Integrated cable management allows you to tuck away cords so that they move with the AHM.
SERVICE COMPANIESView All Patient Cables and Leadwires Companies
  • Can be mounted directly to any equipment rail or wall channel
  • Parallel linkage provides consistent viewing angle at any position
  • Color options available (white is standard)
  • Easy to reposition and lock in place
  • Easy to change monitors
  • Lock Arm in any position
  • Durable, aluminum body
  • Handle for easy tilt adjustment
  • 180° side to side motion
  • Quick pin release for single hand monitor removal
  • Integrated Cable Management
  • 18" - 34" (45.7 cm - 86.4 cm) reach
  • 40 lbs (18.1 kg) arm rating
  • 30° tilt limit - on specific models
  • 17" (43.2 cm) of height adjustment
  • 0 - 40 lb (0 - 18.1 kg) counterbalance adjustment range
