Draeger - JM-103
by Draeger
Transcutaneous bilirubin (TcB) measurement offers a gentle, pain-free alternative to traditional jaundice screening. There’s no blood draw, removing a major stress from fragile babies and their parents. Think of it – no more delays waiting for laboratory results. When used with other clinical signs, it is just reliable information for expert decision-making. Because the Dräger Jaundice Meter JM-103 features a reusable probe tip, it requires no costly disposables. With the volume of screenings performed in the nursery, the cost of such disposable items can quickly exceed the initial cost of the device itself. What you get with the Dräger Jaundice Meter JM-103 is consistent quality, cost-effectively delivered over the lifetime of the device. The Dräger Jaundice Meter JM-103 is a solution specifically designed to efficiently overcome the challenges faced when managing jaundice. Complete this vital task in the fewest possible steps to free up more time for infant care. Its ergonomic, compact design promotes ease of use, while long battery life enables you to get more done between charges.
0RepliesMon Jan 16 2017 | Is this a point of care device requiring Lab oversite Is this a point of care device? Is this a waived test? Reply |
7RepliesSat Sep 24 2016 | Calibration Procedure Is there a calibration for this JM-103 if the tests are outside of the stated values with their tolerances? Reply |
1ReplySun Sep 11 2016 | Operator's Manual Need manual to learn how to test jaundice meter for accuracy, specifically the parameters as I know how to perform the test. Reply |
[list] [*] Reusable Probe - Just wipe with alcohol and reuse as needed. There are no disposable tips to fumble with, keep track of or reorder. [*] Portable Convenience - Compact device fits easily in hand or pocket and allows for quick clean-up between uses. [*] Ergonomic Design - Controls assure convenient operation while helping seal out contaminants and extend device life. [*] Easy-to-read Display - See results in seconds, not hours. Large numbers help ensure accurate interpretation. Results are shown in mg/dL or Μmol/L as selected by user. [/list]
| Height | 15.4 cm |
| Length | 3.2 cm |
| Weight | 150 g |
| Width | 4.8 cm |
Operating temp: 10C to 40C AC adapter output: 9V, 500 mA, 4.5W
The FDA has identified this as a Class I recall, the most serious type of recall. Use of these devices may cause serious injuries or death
