Ferno-Washington - Whirlpool Bath Model 100
Mobile Hydrotherapy Unit.
The Ferno Ille Hydrotherapy Unit Whirlpool model 401 is designed to give immersion hydrotherapy to a patients arm. It features a mobile therapy tank with fill and drain components, a Model 100SASS Turbine to generate a therapeutic flow of water, and a thermometer to measure the temperature of the water. The thermometer is a sanitary, solid-stem bimetal type with a 3" dial. It is mounted inside the tank, and has a dial range of 40ºF to 140ºF (5ºC to 60ºC).
Bath length: 28"
Bath width: 16"
Bath depth: 16"
Height without turbine: 34"
Height with turbine: 52"
Water capacity: 22 gallons
115V, 8.0A, 60 Hz
