Barnstead - Lab-Line Imperial III
This product is Discontinued
Dry Incubator
The Lab-Line Imperial III Incubator, Model 302, is designed for work requiring controlled temperatures up to 65°C and Hydraulic thermostat controls temperature with a second independent safety thermostat for added protection. Features a fiberglass-insulated body and door prevent temperature fluctuations and heat loss and convenient top-mounted controls.
- Durable Heating Elements
- Easy-to-Read Digital LED Temperature Display
- All Controls are Positioned at Eye Level for Convenient Monitoring
- Chrome Plated Wire Shelves are Adjustable on Half Inch Centers and Slide Out for Easy Clean Up
- Gravity Convection Model Reduces Air Movement Helping to Prevent Cross Contamination of Samples
- Tempered Glass Inner Door Allows Samples to Be Inspected Without Disturbing the Chamber Environment
- Microprocessor Based PID Temperature Control Up to ±0.5°C from 5°C Above Ambiento 65°C With Over Temperature Protection
- Temp Range: +/- Slightly above ambient to 65°C
- Temp Uniformity: +/- 0.9°C (Gravity)
