Chattanooga - Optiflex 3 CPM
by Chattanooga
Postoperative Knee CPM used for ACL and Total Knee Replacement repairs.
The Optiflex® 3 Knee CPM is typically used postoperatively for Total Knee Replacement and Anterior Cruciate Ligament (ACL) repairs. After extensive joint surgery, if a patient fails to move the joint, tissue around the joint will become stiff and scar tissue will form, resulting in a joint with limited range of motion. By repeatedly flexing and extending the affected joint through a prescribed range of motion for an extended period of time, the OptiFlex® 3 CPM device lessens the adverse effects of immobilization and trauma on the knee joint.
- Knee Flexion: 120 Degrees
- Knee Extension: -10 degrees
- Speed: 30 - 150 Degrees / Minute
- Pauses: 0 - 30 Seconds>br> - Force Reversal: 35 - 75 lb (16 - 34 kg)
- Maximum Patient Weight: 350 lb (159 kg)
- Calf Length Range (knee joint to sole of foot): 10" - 23.5" (25.4 - 59.7 cm)
- Thigh Length Range: 12" - 19" (30.5 - 48.3 cm)
- Mains Power: 100 - 240 V, 50/60 Hz
- Unit Weight: 27 lb (12 kg)
- Length: 37" (94 cm)
- Electrical Safety Class: Class 1, Type B
- Safety Tests: UL/IEC/EN 60601-1, IEC/EN 60601-1-2:2001
