Kinetec - Centura S1
Anatomical Shoulder CPM Machine.
The KINETEC CENTURA is composed of 5 complementary and anatomical movements covering most of the shoulder pathologies: Abduction / Adduction - Aduction/Adduction with sychronised rotation Shoulder Rotataion - Shoulder Flexion / Extension - Horizontal Adbuction.
Easy left to right arm switch system
Patient set-up is anatomical, comfortable and quick with an intuitive colour- coded system
Evolution Compliant
The KINETEC CENTURA is available in different versions to fit with your daily requirement and use. The device has been designed with additional modules so the user can upgrade the product as required
Kinetec Data CaptureTM USB technology ready
The KINETEC CENTURA remote control feature the latest USB technology enabling the use of the KINETEC DATA CAPTURE software and patient USBs to track patient progress as well as pre-program the entire patient rehabilitation protocol.
- Patient sizing: from 1.4 to 2m
- Maximum user weight: 130kgs
Load reverse ensures patient protection when excessive force is exerted on the joint - Adjustment of the inversion force: 6 levels
Possibility to block the adjustment of the parameters
Resetting of the parameters when changing of the movement, to allow an incompatible range of motion with the patient condition
Automatic movement (continuous) or manual
Function detection of the maximum patient range of motion (manual mode or By-Pass mode) - Adjustment of the session time: from 1 minute to 24 hours
Pause in movement limit: from 1 second to 15 minutes
Adjustment of the speed from 50 to 140° per minute (5 levels)
Possibility of customisation and storage of 16 rehabilitation programs - Dimensions: 56cm x 100cm x 76cm (variable height)
- Voltage: from 100 to 240Volts 50/60Hz
- Electrical power: 50 VA
- Warranty: 2 years
