Focus Medical - Naturalase ER
Erbium laser designed for ablative skin rejuvenation.
The NaturaLase Er is ideal to remove superficial lesions and pigmented lesions and has the power to ablate thick or deep lesions as well. The NaturaLase Er is the highest power Er:YAG available. With 3 Joules per pulse and up to a 10mm spot size the specs are without comparison. High power allows for the versatility a physician needs to provide a wide range of treatments to a wide range of patients. Anywhere from a light "Weekend Peel" to a face lift type procedure, the NaturaLase Er will help you succeed.
0Replies4 years ago | Looking for User's Guide & Operator's Manual for NaturaLase Q Switched 1064nm Nd:YAG Laser by Focus Anyone have & willing to share the User's/Treatment Guide & Operator's Manuals for the NaturaLase Q Switched 1064nm Nd:YAG Laser by Focus Medical? My email if this is a preference or common sharing protocol for such: NuYuShana@yahoo.comReply |
- Laser Source: Er:YAG
- Pulse Energy: Up to 3 Joules per pulse
- Wavelength: 2.94 nm
- Delivery System: "Long Reach" Articulated Arm
- Fluence: Up to 20 Joules/cm2
- Hand Piece: Variable Spot Collimated
- Power Requirements: 110, 200, 220, or 240 VAC
- Spot Size: Up to 10 mm
- Dimensions: 27"(66 cm) x 17"(43 cm) x 50"(124 cm)
- Weight: 200 Lbs. (91 kg)
