Amico - ICU Bed
by Amico
Eight-Function Electrical Bed
The new Amico ICU bed features a versatile design suitable for a wide range of patients. The ICU bed is differentiated by its enhanced chair position as well as its ergonomic and robust design. This product truly helps provide a more meaningful level of care to patients.
This bed has a battery back-up system to enable motion even when the bed is disconnected or during patient transport. The ICU bed also features LINAK™ DC actuators that offer a reliable yet silent motion for the bed’s electromechanical system.
Key Features
  • 550 lbs (250 kg) weight capacity
  • Standard fifth wheel for improved mobility
  • 21" (53 cm) low height
  • Storage area in base for two oxygen E-cylinder tanks and belongings
  • Radiolucent fowler section
  • Dual brake pedal mechanisms
  • Adjustable knee gatch for enhanced comfort
  • Fold-down siderails
  • 8" (20 cm) wheel casters
  • Pressure relief surfaces
Standard Features
  • LINAK™ DC Actuators
  • Modular battery backup
  • LED night light
  • Four IV pole sockets
  • Four integrated roller bumpers
  • Metal litter deck
  • X-ray cassette holder
  • CPR release system
  • Trendelenburg and reverse Trendelenburg
  • Patient controls on inner siderails
  • Flat litter deck for compatibility with standard patient surfaces
  • Adjustable bed height
  • Adjustable foot extension
  • Adjustable litter with chair position
  • Integrated Digital Scale
  • Patient Exit Alarm
  • Scale and Fowler Angle Indicator on Siderail
  • Foley Bag Holder
  • Integrated push handles
  • 5th wheel for improved mobility
Optional Features & Accessories
  • Removable IV pole - 2 stage
  • IV hook
  • Siderail covers
  • Overbed table
  • Brake not set alarm
  • Communication to nurse call systems
  • Oxygen tank holder
  • Bed Exit Alarm
  • Fowler Angle Indicator
  • Hand pendant controls
  • 3-Zone Bed Exit Alarm
 Model Number
  • Model Number: B-E-AC802
Overall Dimensions
  • Overall Length
    • Retracted: 83" (211 cm)
    • Extended: 91" (231 cm)
  • Overall Width
    • Siderails Up: 42" (107 cm)
    • Siderails Down: 38" (96.5 cm)
  • Patient Surface
    • Retracted: 32" x 71" (81 cm x 180 cm)
    • Extended: 32" x 79" (81 cm x 201 cm)
  • Height Range (to the surface of the litter)
    • High: 38" (96.5 cm)
    • Low:5" (52 cm)
Litter Positioning
  • Trendelenburg/Reverse Trendelenburg:± 18°
  • Backrest: 0° - 70°
  • Knee Gatch: 0° - 21°
Weight Capacity & Caster Diameter
  • Weight Capacity: 550 lbs (250 kg)
  • Caster Diameter: 6" (15 cm)
Electronics
  • Volts
    • Domestic: 120 VAC
    • International: 220 VAC
  • Ampere Rating
    • Domestic:5 A
    • International:0 A
  • Current Leakage: <300 μA
  • Frequency: 50-60 Hz
  • Hospital Grade Plug: Yes
