Arjo - Typhoon
Washer/Decontaminator
Typhoon is known for its View in Process (VIP) glass door, which allows you to check on the progress at any time during the cleaning and disinfecting cycle. Its automatic sliding door with built-in IR sensor supports touch-free operation – simply wave your hand in front of the door to open and close it. Typhoon also comes with an automatically rotating holder. Once the door is locked, the holder rotates 150° and empties the receptacles, eliminating the need to manually invert them. At the end of the cycle, the Pipe System Disinfection (PSD) feature automatically disinfects the machine’s internal pipe and nozzle system.
0Replies2 years ago | F1 temperature probe the typhoon bedpan washer gives me an error F1 of temperature probe. I changed it but it continues to go into alarm. the problem is on the board. someone can tell me how to enter the service and return to factory settings?. I can't find the code to enter level D someone can tell me the code? Reply |
2Replies4 years ago | Access I am trying to inspect this unit prior to purchase. It uses 3Ph power and none is available. Is there some way without access to power I can trip / bipass the door locking mechanism so that I can open the outer stainless door and inner glass door?Reply |
- View in Process
- Touch free operation
- Effective cleaning and disinfection
- Digital display indicating cycle progress and disinfection level
