Beckman Coulter - UniCel Dxl 600
by Beckman Coulter
Immunoassay system
The UniCel DxI 600 Access Immunoassay System helps laboratories running 40,000-80,000 tests per year meet peak workload demands with throughput of up to 200 tests per hour and up to 60 samples on board.
-Joanie
Fri Oct 16 2020
decontamination
How is decontamination handled if moving equipment?  For a Beckman Coulter UniCel DxI600
  • Height: 67 in (170 cm)
  • Width: 61.5 in (156 cm)
  • Depth: 37.5 in (95.5 cm)
  • Weight: 1065 lbs (483 kg)
  • 60 sample tubes (15 racks of four tubes), continuous loading
  • Primary tube released after aliquot is made (≤ 5 min.)
  • 300 aliquots (≤ 200 L) per hour
