Beckman Coulter - Optima LE-80K
Preparative Ultracentrifuge
The Beckman Optima™ LE-80K Ultracentrifuge offers the fastest separations possible in the minimum amount of time with its performance capability of up to 80,000 rpm. This versatile model is compatible with a wide range of superior rotors and tubes. Capable of rapid run times, the Optima™ LE-80 K is perfect for a broad range of applications.
4Replies3 years ago | Speed Calibration Does anyone have the testpoints required to calibrate the tach output on the Beckman Coulter Optima LE-80K centrifuge? Also, is there conversion factor to apply to the reading and do you know it?Reply |
- Frequency-controlled, air-cooled direct-drive induction motor
- CFC-free cooling system
- Overspeed safety system
- Dual purpose digital display
