AM Bickford - 51110
by AM Bickford
Veterinary Anesthesia Machine
Model 51110 veterinary anesthesia machine is the basic stand model and all other models evolve from it.  It is a safe, easy to use anesthesia delivery system. A highly maneuverable base with a small footprint, features two easy to lock brakes.  The unique absorber pole design provides ultimate flexibility.  All functional elements are front facing (controls, gauges, oxygen flush, flowmeter & vaporizer) within easy reach and highly visible.
  • Quick release toggle latches for easy to change absorbent (prepack or loose granules).
  • Pressure manometer
  • Air intake valve
  • Pop off valve (see through, easy to clean).
  • Horizontal inhalation and exhalation valves to prevent valves from sticking in the open position
  • O2 flowmeter 0.2 L to 5 LPM.
  • O2 flush
  • Compact, very mobile
  • Absorber pole allows absorber to adjust up or down and also swings out of the way when not in use.
  • Stand provides excellent stability
  • Quick & easy switch over from rebreathing to non rebreathing system
