Veterinary Anesthesia Machine
The Model 52111 is equipped with two O2 flowmeters one high 0-5 LPM and one low 0-1 LPM. This superb design, includes one “E” cylinder yoke that allows the veterinarian to deliver anesthesia where a connection to a main O2 system is not accessible or provides a backup source of O2 when connected to a main O2 system.
- Quick release toggle latches for easy to change absorbent (prepack or loose granules).
- Pressure manometer
- Air intake valve
- Pop off valve (see through, easy to clean).
- Horizontal inhalation and exhalation valves to prevent valves from sticking in the open position.
- Two O2 Flowmeter (one high 0-5 LPM, one low 0-1 LPM).
- O2 flush
- Compact, very mobile
- Absorber pole allows absorber to adjust up or down and also swings out of the way when not in use.
- Stand provides excellent stability
- Quick & easy switch over from rebreathing to non rebreathing system.
