AM Bickford - 51112
Veterinary Anesthesia Machine
The BICKFORD Model 51112 is designed to give the veterinarian that added security of having 2 oxygen “E” cylinder yokes to hold two oxygen tanks. Each yoke has its own single stage regulator to assure proper supply pressure.
- Quick release toggle latches for easy to change absorbent (prepack or loose granules).
- Pressure manometer.
- Air intake valve.
- Pop off valve (see through, easy to clean).
- Horizontal inhalation and exhalation valves to prevent valves from sticking in the open position.
- Two oxygen “E” cylinder yokes
- O2 flowmeter 0.2 L to 5 LPM.
- O2 flush.
- Compact, very mobile.
- Absorber pole allows absorber to adjust up or down and also swings out of the way when not in use.
- Stand provides excellent stability.
- Quick & easy switch over from rebreathing to non rebreathing system
