Matachana - MINICLAVE M20-B PLUS
by Matachana
Sterilizers/Autoclaves
The MATACHANA sterilizer M20-B plus entails the confirmation of the latest technology in steam sterilization applied to a table top sterilizer. It is designed to meet the daily needs encountered in day care centers, casualty department, dentists, hygienists and aesthetics cabinets, veterinary practices, etc., and is likewise very necessary as a support device in the surgical block.
  • Vacuum system equivalent to the large sterilizers
  • Microcomputer controlled by non-stop monitoring of cycle development
  • Easy to operate by means of touch screen with user’s menu simple and intuitive
  • USB port for easy download of cycle logs
  • Patented system that automatically adjusts the drying time depending on the volume of the load. Significant reduction in cycle times. ECO-DRY FUNCTION
  • Programmable cycle start
  • User management
  • Cycle times 21 to 44 minutes with automatic drying based on load type
  • Rapid cycle, 13 minutes
  • Low consumption of water and power
  • Integrated conductivity sensor
  • Patented system of filter and water separator to extend the vacuum pump lifespan
  • Integrated automatic system for water tanks’ supply and drain
  • Ethernet communication port
  • External printer (optional)
