Interacoustics - VN15
The VN15 is similar to the VO25, but does not include the VisualLab for the specialized oculomotor testing.The VN15 is similar to the VO25, but does not include the VisualLab for the specialized oculomotor testing. The VN15 records the patients eye movements using the same mask and camera system as used with the VO25. The PC-based system then analyzes the video images.
The Examination Designer allows the creation of your own test protocol. Once the protocol is defined you can step through the examination by simply pressing a footswitch. It couldnt be any easier! During the examination the test view provides you with graphical data and immediate »On Line Analysis« while simultaneously displaying the eye images for subjective control during the
exam. The examiner can even type in comments while the test is in progress. These features greatly reduce the number of time consuming steps often involved in generating test data.
- Reader station for remote data access
- Setup to record rotary chair movement
- Separate monitors for easier visualization of the eye
Height | 38 mm |
Length | 25.5 cm |
Weight | 17.9 kg |
Width | 36.6 cm |
