Dison - BB-100
by Dison
Infant incubator
-Joaquin Burla
Sat Apr 17 2021
Technical Support
Can anyone help us, please provide us a service manual of BB-100 Incubator, we really need data/specs for our calibration. Thank you very much. JoaquinReply
5
-Clemence
Fri Mar 19 2021
Actual temp on chamber is lower by 1.8 deg vs the set point.
chamber temp is 34.2degC lower by 1.8deg C versus the set point of 36degC. There are two(2) potentiometer on the control board (1009BB100). Can somebody share the User Manual and circuoit diagram of the control board (1009BB100).Reply
  • Microprocessor based servo controlled temperature system Control modes: Air mode Humidity is adjustable continuously
  • Set temperature, air temperature, heating power are displayed separately by LED Self - testing function, various failure alarms by audible and visual
  • Alarm function: Power failure,Over temperature,Temperature deviation,Fan failure,Temperature sensor failure >37° temperature set function
  • Triple protection for over temperature with separate cut off device, more safety system
  • The inclination of infant bed is adjustable
  • Single wall hood, 4 operating windows and 2 iris ports,3 infusion seals Independent locking device for front door
