Memmert - WB-OR 7-45
by Memmert
Washer/Decontaminator
MEMMERT-waterbaths are electrically heated and electronically controlled. The temperature of the thermostating liquid is continuously controlled by a microprocessor-controller with pulse package control. Electronic microprocessor-PID-controller with continuous power matching and autodiagnostic system with fault indicator integral timer for digital programme time selection
  • Boiling mode for temperatures above 95°C
  • High-grade stainless-steel Pt100-temperature sensor (Mat.Ref. 1.4571) Class A in 4-wire circuit
  • Monitor relay to switch off heating in case of fault
  • Visual alarm indication
  • Mechanical temperature limiter (TB Class 1)
  • Operating voltage see rating label 50/60 Hz
