Sanyo - MLS-3780
by Sanyo
Autoclave
High pressure autoclaves are the most popular method of sterilization used in today's laboratories. Autoclaves are used in a wide variety of applications. SANYO MLS-Series top-loading autoclaves provide a safe, reliable high pressure steam sterilizing environment within a self-contained unit that is particularly easy to use. These reliable, energy saving autoclaves are ideal for a wide range of applications.
-Ross
Fri Aug 18 2023
Sanyo MLS 3780 autoclave lid seal
Does anyone know of a source for a lid seal for the Sanyo MLS 3750/3780 top-opening autoclave? Sanyo was, IIRC, purchased by Panasonic, but then they quit manufacturing autoclaves.
-Ross
Wed May 12 2021
Sanyo MLS-3780 autoclave display doesn't light
A customer has a Sanyo MLS-3780 floor model autoclave. The display board does not light up or react to buttons in any way. The lid lock functions do work. 5V on the connector (on the main pcb) to the display board drops to about 4V when the connector is inserted. It looks like a problem with the display board. Does anyone have a source for parts, or advice?Reply
  • Technical specifications: 250 VAC, 20 A.
  • Temperature range: 10-137,9ºC.
  • Sterilization temperature: 105-135°C.
  • Capacity: 83 liters.
  • Housing (D)x(H)x(W): 60 x 98 x 56 cm.
  • Interior (ø)x(D): 37 x 64 cm.
