Omron - M7 Intelli IT
Blood Pressure Monitor
The M7 Intelli IT is a clinically validated, Bluetooth enabled, blood pressure monitor that detects the possibility of Atrial fibrillation (AFib)
2Replies3 years ago | Calibration How can I access the service mode to perform a static calibration check?Reply |
SERVICE COMPANIESView All Blood Pressure Monitor Companies
- The Omron M7 Intelli IT blood pressure monitor, which also detects the possibility of Atrial fibrillation (AFib).
- Atrial fibrillation often goes undetected as it can be present without symptoms. The AFib function of the Omron M7 Intelli IT indicates potential AFib with high specificity (93.8 Percent) and sensitivity (95.5 Percent).
- When in AFib mode the Omron M7 Intelli IT takes three blood pressure readings and gives the average, which is a realistic indication of your morning and evening blood pressure over time.
- While measuring your blood pressure, should the device detect an irregular heartbeat on two or more occasions, you’ll see the AFib indicator flash up. This is not a diagnosis. It is only a potential finding for AFib.
- Keeping track of blood pressure has never been easier than with the Omron M7 Intelli IT. The new design features a comparison mode allowing user to compare results from the 100 blood pressure readings it can store. User can also view weekly, morning or afternoon averages.
- User can also automatically transfer the blood pressure readings to your smartphone, once paired by Bluetooth, the Omron M7 Intelli IT will update the Omron connect app with all the latest measurements. The Omron connect app lets the user follow progress or share your readings with your doctor. User can also keep track with Alexa just ask, “What’s my latest blood pressure reading” or compare averages over time.
- Part of the Omron smart ecosystem to help you influence your heart’s health. The Omron connect app links Omron’s smart blood pressure monitors with VIVA the smart Body Composition Monitor – combining to give you more understanding of what effects your heart’s health.
- Upper arm blood pressure monitor
- Intelli Wrap Cuff 22–42 cm
- Memory 2 Users x 100 Readings
- Clinical Validation, Diabetic Validation, Pregnancy Validation
- Body movement detection
- Irregular heartbeat detection
- Compatible with Omron connect app
