MOCOM - Supreme
by MOCOM
Autoclave
This performance eliminates waste, reduces costs and ensures a significant increase in the efficiency of any modern dentistry surgery. It also solves all issues relating to demineralized water storage and supply. Unlike traditional sterilizers, Supreme does not require any external water connection for mains water treatment. The nano-ceramic recirculation filter, incorporated into the secondary tank, makes it possible to distil and purify water so that it can be reused in the following sterilization cycle. The built-in conductivity sensor ensures compliance with water quality parameters as it protects the machine internal components from excess lime. At the end of each sterilization cycle, the machine stores a report inside its memory.
The user can download the cycles in PDF format at any time through the front USB port or automatically store them in the cloud using the WiFi and Di.V.A. system.
  • 50 sterilization cycles with 5 liters of tap water
  • 100 ml/cycle, a real revolution
  • 7'' touch screen monitor
  • WIFI
