Eschmann - T20-a : T20-s
The T20 - a+ / s+ tables have excellent imaging access enhanced by 250mm traverse and an offset column.As with all Eschmann products the T20 - a+ / s+ operating tables were designed with 'simplicity and intuitiveness' in mind, having drawn influences from leading clinicians of various levels from across the globe.The T20 - a+ / s+ tables have excellent imaging access enhanced by 250mm traverse and an offset column. With a maximum patient weight of 450kg (70 Stone) and a 600mm tabletop width the T20 - a+ / s+ is capable of supporting the most demanding of surgical needs. An excellent range of accessories are available that further enhance each tables capabilities. The T20 - a+ / s+ powered operating tables feature interchangeable head and leg sections and an acrylic capped ABS top prevents fluid ingress, is easy to clean, scratch resistant and hard wearing.
FORUMSView All (5)
4Repliesa year ago | Electronics broken We are a Vet Hospital in QLD Australia and have 2 tables that won't move ie their electronics has broken. Can we convert the tables into purely manual to do away with the electronics? If we can, anyone help us how? Regards, Guy Equipment: Eschmann t20 Reply |
1Reply4 years ago | Eschmann T20 Series Hai, anyone have the details of T20 Series model variations? Thanks.Reply |
1Reply5 years ago | Eschmann T20a I have a fault on power supply to battery's any tried to repair this unitReply |
- Full length radio translucent top with built-in x-ray cassette tunnel accessible from either end
- 720-1120mm height range
- 450kg maximum patient weight
- Powered 250mm table top traverse
- 600mm wide table top (across sidebars)
- Corded handset controlling Trendelenburg, reverse Trendelenburg, lateral tilt, flexion/extension, traverse, auto level, and height,Offset table-top break and offset slimline column for superior imaging and access
- Column covers in stainless steel
- Battery powered (mains rechargable)
- Foot pedals on base to control brakes, wheels and castors for stability, straight-line steering and 360 degree mobility
- Head and leg sections are removable and interchangeable, with an auto-locking mechanism
- Covers to the top and base are made of scratch resistant and colourful acrylic capped ABS mouldings to minimise potential sites for cross contamination and provide a wash down surface to the tabletop
- Simple mattress fixings, no velcro
- Special one-piece mattress covering break position (long and short trunk sections) to combat fluid ingress and to provide superior patient support
Height | 720 mm to 1120 mm |
Length | 2102 mm |
Tredelenburg | 25 degrees |
Lateral Tilt | 18 degrees |
Patient Weight Capacity | 300 kg |
Width | 600 mm |
