Siemens - Hematek 3000 System
Hematology analyzer
Complementing the Siemens Healthineers family of hematology analyzers, the Hematek® 3000 System provides semiautomated slide staining for laboratories that need a robust system capable of staining up to 60 slides per hour. Built on a heritage of slide staining spanning more than half a century, the system helps maximize productivity and deliver quality results through user-defined features and precision controls.
FORUMSView All (6)
0Replies3 months ago | need a service manual If anyone has a service manual they can share it. I have a part that fell out and I need to see where it goes. The unit is having motor issues. Reply |
0Replies10 months ago | Blower fan failure Has anyone come across a supplier of the blower fan. Mine has quit working completely. I originally thought something was jammed in the fan but it is free and clear and not running. Since Siemens no longer does exchanges unless the system is under warranty i need to find a way to replace the fan. Also a prts breakdown or service manual would be helpful but i prefer finding a replacement fan more. Reply |
4Replies2 years ago | NEED A SERVICE MANUAL I got these rattling sound whenever I turned-on the unit. And the black rollers does not turn. It looks like the motor, or a stuck-up motor. I need the service manual with exploded view of the parts. I hope you could provide me with it. Thanks guys. Equipment: HEMATEK 3000 STAINING SYSTEM Reply |
- All-in-one stain pack includes enough stain for up to 900 slides and offers easy load-and-go operation for optimized daily workflow with minimal hands-on time
- Pumps deliver a fresh, precise volume of reagent for every slide, while the platen provides uniform stain from field to field and slide to slide with accurate mixing and uniform stain and buffer delivery
- Simple pump release mechanism streamlines maintenance
- Slides are immediately available for viewing upon completion of staining, and the rinse reagent contains the optimal alcohol concentration for proper slide drying
- System warnings alert users of low stain-level and full waste bin to help ensure uninterrupted, quality results
- Dimensions 22x54x46 (8.7x2.3x18.1)
- Weight 20 (44)
- Processin system - Platen
- Power requirements - 110-230 volts
- Dryer - yes
- Temperate storage- room temperate
