Eschmann - T30+
by Eschmann
Enhanced by its versatility and modularity the T30+ system is, in essence, two operating tables in one. Designed for general, specialist procedures.
The T30+ design draws is strengths from the distinctive features of the current T20 range.Enhanced by its versatility and modularity the T30+ system is, in essence, two operating tables in one. The T30+ is designed for general, specialist and orthopaedic procedures. The design of the modular, interchangeable table top sections allow quick set up between cases and reduced manual handling. A range of 6 options designed to meet the most frequently used configurations and the ability to build a bespoke system by selecting from a wide range of accessories, makes the T30+ the table of choice.
-Kamariah
a year ago
Orthopaedic ot table
Specification
Equipment: Eschmann - T30+
-RaviH
7 years ago
ESCHMANN T-30 OPERATING THEATER TABLE
Can you explain the reason for flickering of remote loop LED of the Eschmann T-30 Theater  table.
[list]      [*] Modular, interchangeable tabletop sections which allow easy configuration for all surgical procedures.       [*] A range of six options designed to meet the most frequently used configurations - general, orthopaedic and specialist procedures.       [*] The ability to build a bespoke system by selecting from a wide range of additional accessories.       [*] A unique orthopaedic docking cart that facilitates rapid and secure table set-up.       [*] A superior range of table movements easily controlled via the hand control.       [*] Optional table bases for enhanced manoeuvrability to accommodate a range of theatre environments.       [*] Lightweight superior quality mattresses that span the table break for improved patient comfort.       [*] Pressure relieving visco elastic foam, which moulds to the contours of the patients body for improved support.      [/list]
Height720 nm to 1120 mm
Tredelenburg 35 degrees
Lateral Tilt18 degrees
Patient Weight Capacity450 kg
Width600 mm
Max flexion 90°       Max extension 230°       Head section adjustment +/- 45°       Leg section adjustment -100° +55°       Table top length 2135mm and 1885mm without infill section
