The Innova IGS 5 system is designed to support a variety of procedures such as cardiovascular, Electrophysiology, Oncology and neuro interventions procedures. It is designed from the ground up to provide the im age clarity you need while helping you keep dose as low as possible.
- With its unique offset C-Arm, the Innova IGS 5 enables improved access to patient head in complex interventions and helps cover head to groin without moving the gantry.
- In addition, the C-arm design allows you to perform 3D rotational acquisitions of the spine and torso as well as patients’ head while intubated.
- The offset C-arm permits fast-spin rotational angiography over a maximum range of 200°at variable speeds from 20°to 40°/sec (maximum speed of 30°/s from LAO to RAO) with flexible cranio/caudal oblique angulations.
- The comfortable, easy-to-grasp control knob makes it easy to pan the table, position the gantry, and perform procedures.
- With a choice of 3 square panels (20.5 x 20.5 cm (8.1 in), 31 x31 cm square (12.2 in), or 41 x 41 cm (16.1 in)), we have the size you need to achieve all kinds of interventional procedures.
- The Central touchscreen lets you control most system functions, configure the system, modify imaging parameters, control your large display monitor3, and manipulate advanced applications –all at the tableside
