Eschmann - T20 -m+
T20 - m+ powered operating table with mobile base, has been designed to accommodate theatre environments that require the functionality of a trolley.The T20 - m+ powered operating table with mobile base, has been designed to accommodate theatre environments that require the functionality of a trolley system whilst maintaining the performance of a static operating table for a complete range of general and specialist surgical procedures. When used as a static platform the T20 - m+ will safely accommodate a patient weight of 450 kg (70 stone).A full range of accessories are available to further expand the capabilities of the T20 - m+ operating table, with a traversing, fully radiolucent top allowing easy access for C-arm imaging. The mobile base features four 125mm castors with castor covers colour co-ordinated to the table.A new easy to operate brake system with 3 positions that can be easily selected, fully locked for stability during surgical procedures, or full 360° rotation or front castors directionally locked for ease movement in a straight line along corridors.
FORUMSView All (3)
2Replies5 years ago | T20 a Theater Table Service Manual Hello, I am looking for a service Manual for the T20a Theater Table, Can some one please help with either a Pdf Service Manual or a link to obtain one, Many Thanks In advance MarcReply |
0Replies5 years ago | T20a Eschmann Service Manual Hello, I am looking for a service Manual for the T20a Theater Table, Can some one please help with either a Pdf Service Manual or a link to obtain one, Many Thanks In advance MarcReply |
0Replies7 years ago | problem charger does anybody has service manual for this device?Reply |
[list] [*] T20 - m+ model features larger castors and unique brake pedal design [*] Full length radio translucent top with built-in x-ray cassette tunnel accessible from either end [*] 720-1120mm height range [*] 450kg maximum patient weight [*] Powered 250mm table top traverse [*] 600mm wide table top (across sidebars) [*] Corded handset controlling Trendelenburg, reverse Trendelenburg, lateral tilt, flexion/extension, traverse, auto level, height, and battery life indicators [*] Offset table-top break and offset slim line column for superior imaging and access [*] Column covers in stainless steel [*] Battery powered (mains rechargeable) [*] Head and leg sections are removable and interchangeable, with an auto-locking mechanism [*] Covers to the top and base are made of scratch resistant and colourful acrylic capped ABS mouldings to minimise potential sites for cross contamination and provide a wash down surface to the tabletop [*] Simple mattress fixings, no velcro [*] Special one-piece mattress covering break position (long and short trunk sections) to combat fluid ingress and to provide superior patient support [*] Supplied with 50mm deep mattress [/list]
Height | 720 mm to 1120 mm |
Tredelenburg | 35 degrees |
Lateral Tilt | 18 degrees |
Width | 610 mm |
