Techne - DB100/3
by Techne
Digital Dry Block heater
Techne® Dri-Block® heaters have been providing a safe, dry, constant temperature source in the laboratory for 50 years. Now Techne® are proud to introduce the new 2014 range offering market-leading choice, flexibility and specification. Dri-Block® heaters are a source of precision temperature control for general heating and incubating applications as well as sensitive analytical procedures particularly suited to microbiology and clinical laboratories. They are designed for precise heating of test-tubes, microcentrifuge tubes, cuvettes and microtitre plates. Techne® Dri-Block® heaters cover the temperature range from ambient +5°C to 100°C or 200°C (depending on model) using machined aluminium alloy Dri-Block® inserts as the heat transfer medium. Independent indicator lights indicate mains power and heater action.
-SHAJAHAN K
a year ago
Set temperature doesnt stay stable ,
Once heater reaches set temp value, after 10-15 min the temp display value drops to apx 10 degrees. Did temp calibration as per manual. How to fix it. Can someone post a troubleshooting tips ? and please provide service manual if anybody has . Thanks Reply
  • Small, light, compact footprint - flat top surface allows units to be stacked in storage.
  • Can hold any combination of aluminium insert blocks, depending on the model chosen.
  • Digital models enable highly accurate temperature precision.
  • Temperature range from ambient + 5°C to 200°C depending on the model chosen.
  • Fast heat-up rate: 25°C to 100°C in 7-9 minutes, depending on the model chosen.
  • Advanced temperature control. Temperature stability at 37°C ± 0.1°C.
  • Outer casing is cool to the touch, even at maximum operating temperature.
  • Temperature range from ambient to 100°C or 200°C, depending on the model chosen.
  • Accurate, reproducible, rapid and safe heating of your samples.
  • High quality, precision-engineered blocks provide excellent thermal contact.
  • Choice of models with 2, 3 or 4 interchangeable blocks.
  • Versatile range of interchangeable heating blocks to fit all popular sample tubes and plates.
  • Full range of models and options for basic and advanced applications.
  • Bright orange 5-digit LED digital display for fast and accurate setting of temperature and timer.
