GIMA - DIATERMO MB 122
Electrosurgical System
MB 122 is an HF electrosurgical unit suitable to perform middle monopolar or bipolar electrosurgery. By selection of the modes of operation they provide pure cut, coagulated cut, forced coagulation, soft coagulation and, with forceps, bipolar coagulation. The use of either split or normal neutral plate is allowed.
1Reply3 years ago | repair manual GIMA Derthrmo MB122 I have a unit that outputs no power with out error code or alarm. does any one have the repair manual or circuit diagram for this unit? Reply |
- Single-use two button handles
- Operative foot-switch (usable as alternative to handle)
- Flat neutral plate
- Kit of 6 short autoclavable electrodes (2.4mm x 50mm)
- 180mm Bipolar Forceps with 1mm tips
- Bipolar Cable
• Minimum preselectable power: 0 • Level step: 1 • Maximum output power CUT (W): 120 250 Ohm • Maximum output power BLEND (W): 90 200 Ohm • Maximum output power COAG FORCED (W): 80 150 Ohm • Maximum output power COAG SOFT (W): 60 100 Ohm • Maximum output power BIPOLAR (W): 40 100 Ohm • Working frequency: 600 kHz • Weight kg: 7 • Size LxHxD mm: 260 x 110 x 265 • Operating voltage (switchable): 115 -230 • Mains frequency (Hz): 50-60 • Fuses 230Vac (5x20) TIMED: 2 x 3,15A • Fuses 115Vac (5x20) TIMED: 2 x 6,3A • Electrical input power (VA): 300 • Electrical input current (230 Vac) (A): 1,3 • Electrical input current (115 Vac) (A): 2,6 • Five steps adjustable sound level (from 55- to 75dBA): YES • Self-check: YES • Power accuracy output warning: YES • Split or not split patient plate allowed: YES • Last working condition storing: YES • Electrical Class (EN60601 - 1): I CF • MDD 93/42/EEC Class: II B • Patient circuit: F |
