3M Health Care - V.A.C.ULTA"
Negative Pressure Wound Therapy System
Only V.A.C.® Therapy provides patented SENSAT.R.A.C.™ Technology, a real-time pressure feedback system that adjusts pump output, compensating for wound distance, wound position, exudates characteristics, and patient movement. The V.A.C. VERAFLO CLEANSE CHOICE™ Dressing, when used with V.A.C. VERAFLO™ Therapy, can be used to initiate immediate wound cleansing therapy. The dressing’s unique three-layer design facilitates removal of thick exudate material, such as fibrin, thick wet exudate, and other infectious material, to provide a wound cleansing option for clinicians when surgical debridement must be delayed or is not possible or appropriate. Easy application with flexibility Ideal for dirty wounds needing immediate wound cleansing.
1Reply3 years ago | Life Expectancy for the KCI V.A.C. Ulta Therapy Hi All, does anyone know the normal life expectancy for a wound vac?Reply |
- Cleanse the wound with the instillation of topical wound cleansers
- Treat the wound with the instillation of topical antimicrobial and antiseptic wound solutions
- Heal the wound and prepare for closure
- Contaminated wounds with instillation of topical wound cleansers and
- Infected wounds with instillation of appropriate topical wound solutions and in conjunction with appropriate good clinical practice such as debridement and antibiotic therapy
- Volumetric delivery
- Fill Assist to help determine the correct instill volume
- Dressing Soak to instill topical wound solutions into the wound for easier dressing removal and increased patient comfort
- Unit weight with empty canister: 3.35kg (7.4lbs with a 500cc empty canister and no solution bag)
- Dimensions with empty canister: 217mm x 260mm x 191mm (8.55in x 10.25in X 7.5in)
- Power Supply: Class I Equipment, Ordinary Equipment
- Battery Type: Custom lithium battery
- Battery Life: Approximately 6 hours
- Battery Recharge Time: Approximately 4 hours
- Battery Indicator Three-segment:Low-battery alarm when <2 hours
- Voltage: 100 - 240V AC
- Frequency:50Hz - 60Hz
- Power: 60W
