Hach Company - BD-46
by Hach Company
Block Digestor
The Lachat BD-46 Block Digestor is designed to perform safe and convenient high- temperature digestions such as the Kjeldahl nitrogen digeston and other digestions involving boiling inorganic acids. Its rack system has a capacity of 46 tubes in two sections of 23 tubes each.
-jflor_3584
4 years ago
Calibration/Control adjustment
Does anyone have instructions on alignment of the temperature control/display on the Lachat BD-46 block digester?Reply
  • Models for 46 or 23 tubes
  • Stainless Steel for maximum life
  • Use multiple racks to prepare sample batches (Kjeldal Digestion)
  • Keeps radiated heat around the tubes during digestion
  • Evenly distributes heat
  • No Hot and Cold spots
  • Allows uniform digestion across the block
  • Capture and re-condense digest fumes
  • Reduce acid loss
  • Reduce cross contamination
  • Reduce splatter
  • Stainless steel construction for long life
  • Holds tubes above the Block for rapid cooling
