Armedica - AM-300 Treatment Table
by Armedica
Treatment Table
These treatment tables are what put Armedica on the map… strong, stylish and affordable. For the clinician, the AM-Series offers full height adjustment and section mobility so the patient can be placed in the proper position for maximum results with minimum effort. For the patient, comfort and easy access getting on and off the table.
-dPerk2828
Thu Jul 22 2021
Service Manual
I was wondering if anyone has a Armedica AM300 treatment table service manual. Thanks.Reply
  • 34 oz. Heavy-duty vinyl with Permablok 3(R) bacterial protection.
  • 1” Firm density foam tops.
  • Radiused, seamless corners on upholstered components.
  • Top sections have welded steel support frames.
  • Pivoting joints house hardened steel shoulder bolts with locking nuts to ensure years of trouble-free operation.
  • Footswitch control.
  • Power assisted caster system (unless noted otherwise).
  • Top Section: Three Piece
  • Width: 27″
  • Length: 76″
  • Head Section: One Section
  • 15″ x 27″ Raises 45 degrees. Lowers 90 degrees. Contoured Face/ Nose Opening.
  • Center Section: 22″ x 27″ Raises 30 degrees and has a spring loaded lock that must be released before the section will raise.
  • Foot Section: 39″ x 27″ Raises 73 degrees.
  • 110 volts, 60Hz motor (220 volts, 50 Hz available on special order).
  • 400 lb. Lifting weight capacity (unless noted otherwise).
