ALPINION Medical Systems - E-CUBE 12
by ALPINION Medical Systems
Color Doppler Ultrasound
The E-CUBE 12 incorporates the latest technologies from ultrasound medical device specialist Alpinion Medical Systems, ensuring cost-effectiveness and higher image quality. Just as Alpinion is gearing up for a fresh start for the E-CUBE series with the new E-CUBE 12, your clinic will also be able to boost innovation and growth by using the E-CUBE 12.
-MedWrench Crystalyn
Thu Jul 29 2021
E-CUBE 12
E-CUBE 12Reply
SERVICE COMPANIESView All Ultrasound Companies
VIDEOS
E-CUBE 12
  • Storage: Combination of SSD 120GB for faster processing and HDD 1TB for saving large amount of patient data.3 Step Gel warmer for better patient comfort.
  • Crystal Signature™ and Power View™ Transducer for better penetration and resolution.
  • High density linear and High density Endocavity volume transducer for better resolution.
  • Single crystal high density Convex transducer (1-6MHZ) for better penetration and resolution.
  • Articulating monitor arm and Control panel up/down for height adjustment.
  • Single crystal high density volume transducer (1-6MHZ) for reconstructing high quality 3D/4D images.
  • Volume Master™- ALPINION’s intuitive 3D/4D software package in Convex and endocavity transducers offers fast rendering speed and outstanding rendering quality for diagnosis.
  • Advanced 3D/4D features like Anyslice, Mslice and Volume Analysis for better 3D/4D diagnosis.
  • Live HQ- Premium 3D/4D feature to render a realistic view of fetus.
  • Advanced Cardiac features like stress echo, Cube strain, Auto EF, TDI.
  • Other advanced features like Contrast Imaging, STIC imaging, Strain Elastography, Auto NT, Auto IMT, Needle vision Plus available.
  • Touch Clip feature helps you to compare two different images for better diagnosis.
  • 21.5-inch, FHD (1,920 × 1,080) LED monitor
  • Fully articulating monitor arm for better vision – 140mm up and down, swivel +/- 90°and tilt +15°/ -90°
  • 10.4-inch touch screen- high sensitivity, high resolution
  • High gloss surface control panel
  • Compact transducer connectors and system
  • User-friendly control panel — The height and angle of the control panel can be adjusted easily and conveniently; a sliding keyboard can be used when needed
  • Gel warmer developed for patient convenience
