hu.q - CSP-90 PLATE STACKER
Film Processor Plate Stacker
The CSP Series Plate Stackers are a part of CTP plate processing systems. They are highly automated machines with wide tolerance of processing control adjustment and wide application range. They come in 2 models and both are compatible with the PT-Series Plate Processor. With years of experience manufacturing for Kodak, our plate stackers have been market-tested and have received recognition from our clients for their reliability, high performance and durability. The plate stacker transfers the plates from the plate processor to the cart, this automated process allows user to load the plates without interruption. It can be combined with any CTP-system to create a fully automatic and economic plate processing line, giving you an efficient and cost-saving plate production by eliminating manual handling. Human error occurred during the handling and sorting of plates are avoided, and scratches of plate become a thing of the past.
- Immersed roller with stepless speed regulation, permits an automated work cycle
- Enlarged LED screen, 6-switch operation, user-friendly interface
- Advanced system: independent electric, software control system, programmable microprocessor control system, 3 washing options, developing fluid temperature control system that controls the developing temperature at precisely ±0.3°c
- Developing fluid is replenished automatically according to usage, helps to maintain a longer fluid activity
- Filters can be easily removed and cleaned or replaced in just moments
- Large capacity developing tank, wide Φ54mm(Φ69mm), acid and alkaline resistant rubber shaft, ensures durability and stability of the plate
- Compatible with shaft brushes of different hardness and material
- Rewash function to obtain optimal layout cleanliness
- Energy saving and cost reducing automatic sleep mode, automatic glue recycling system, and highly efficient hot air dryer system
- Upgraded communication interface connects directly with CTP
- Equipped with emergency switch and alert system to prevent malfunction by overheating, dry heating, and low fluid level
- Easy maintenance: shaft, brush, circulation pumps are removable
