X-ray Film Processor
The HQ-350XT automatic x-ray film processor adds efficiency to clinical practices using film radiography systems. It maintains the chemicals required to develop x-ray film and automate the entire process. The exposed x-ray film is fed into the processor and it is developed with the final x-ray print as the output.
- Automatic replenishment function
- Automatic standby mode for conserving water and energy
- Vortex drying system, completes the job more efficiently
- 2 output options: front & rear
- Roller shafts made of high quality plastic, resistant to corrosion & expansion
- Must be installed in dark room, avoid any light leakage.
- Prepare high temperature development chemical wash kit & high temperature/general film in advance (dev/fix powder & low temperature film must not be used).
- Dark room must be equipped with a tap (quick-opening faucet), sewer and 16A power outlet (for safer operation, a water valve is recommended, this tap must be used exclusively by the processor).
- Make sure to do a test run with the X-ray and CT machine after installation for verification.
- If water quality is undesirable, installation of a water filter is strongly recommended.
- Air conditioning in the dark room is strongly recommended.
