Cadwell Laboratories - Cascade
The Cascade amplifier provides the flexibility of a referential amplifier with the super quiet qualities of a true differential amplifier.The Cadwell Cascade is a powerful, multi-modality system capable of performing EP (including SEP, TceMEP, BAEP, VEP), free-run EMG, stimulated EMG, EEG, and train of four tests simultaneously. The Cascade can also be used clinically for multi-channel evoked potential testing and other applications. The Cascade was designed with portability as a priority. The Cascade can be configured with a laptop computer for portability or as a desktop PC-based system.
FORUMSView All (4)
1Reply3 years ago | 16 channel amplifier What would cause the amp to not show impedance values on leadsReply |
0Replies7 years ago | PM Procedure Hello, Does anyone have the PM Procedure for the Caldwell Cascade? Thanks, Reply |
0Replies10 years ago | VEP Can you please indicate what make/model of LCD monitor for VEP check board stimulation is compatible with this Cadwell cascade. It needs to have the (European standard) CE mark Reply |
[list] [*] Crosspoint Technology: flexibility of a referential amplifier with the super quiet qualities of a true differential amplifier [*] All-modality monitoring [*] Robust and reliable hardware [*] Dynamic montaging allows any combination of inputs be connected to a channel for unlimited channel utilization [*] Intuitive and easy to use software that’s fast to set up and simple to learn [*] Remote monitoring for viewing and review data independent of unit in surgery [*] Sixteen unique data-window types [*] Automatic report generator [*] The main amplifier may be placed away from the operating table without any loss of signal fidelity or increase in interference [/list]
Weight | 4.25 lbs |
Channels | 16 |
