Suction Pump
Gomco® constant and intermittent pumps provide exceptional versatility through a unique vacuum capability. This new concept utilizes a diaphragm vacuum source with an automatic lock feature that maintains a separate collection system for the two mode selections (constant or intermittent). UL/ULC listed. Gomco 6037 mobile aspirator specializes in gastric drainage for hospitals and clinics. It generates up to -250 mm Hg for constant suction and up to -200 mm Hg for intermittent suction, with a 20 lpm and 3-4 lpm respective flow rates at open flow. The Gomco 6037 comes with disposable collection canisters.
- Set the mode switch to Constant or Intermittent
- Set the Intermittent timing, if needed
- Turn on the power
- Adjust the vacuum level
- Fully independent constant and intermittent modes
- Adjustable suction timing allows the clinician to tailor treatment to fit individual patients
- Easy-to-store and transport compact design with a flat stainless steel top
- Convenient storage for 6 electrical cord with hospital-grade plug
- Disposable hydrophobic bacteria filter helps prevent fluid and aerosol contamination
- Vacuum Range: Constant: -25 to -250 mm Hg, Intermittent: -25 to -200 mm Hg
- Flow Rate: Constant: 20 lpm at open flow, Intermittent: 3-4 lpm at open flow
- Cycle Times: ON: 5-90 seconds, adjustable OFF: 12 seconds, fixed
- Sound Level: Less than 52 dBA
- Pump Type: Oil-less diaphragm
- Electrical Cord: 6 hospital grade
- Dimensions: 23" W x 17" D x 33" H (109 x 43 x 84 cm)
- Weight: 62 lbs. (28 kg)
- UL/ETL Listed: Yes
- Warranty: 1 year
- Regulatory Approvals: FDA
