ERBA - Laura
Urine Analyzer
LAURA® is an effective solution for objective standard and high-grade measurement of urine samples. The reader is a semi-quantitative semi-automat, which contains advantages as the easy control using a touch screen,, the high speed and capacity of work for the routine operation in laboratories of the clinical chemistry.
LAURA® automatically check itself after each switch-on. The calibration of LAURA® is checking by the control mode from SW menu. The special control strips are using for the checkings of the calibration and the right function of the optical parts. The control grey strips are a part of a delivery or it is possible to buy them separately also.
LAURA® has a wide-ranging software menu, which allows to the user to make for example the own settings for inserting of the samples, a choice of units and the order of measurement parameters without reference at the order on the strip. The SW allows to add the short commentary to the each measurement, to choose the language fot the communication with the reader (there are 8 languages) and lot of another user-defined settings.
The LAURA® has a standard interface (RS 232) for a connection to the Laboratory Information System (LIS). The interface is suitable for connection with a PC also. The LAURA® has the standard connecion (PS/2) for connection with an external keyboard or a bar code reader.
- semi-automated semi-quantitative reflex photometer
- measuring using a CCD camera/LED
- wave lengths: 535, 610 nm
- latency: 60 s
- capacity: 400 strips per hour
- Touch screen (LCD display): 5“ (320x240) colour TFT
- user-defined setting option
- built-in thermo printer, print speed 12 results per minute
- external communication via RS 232 interface
- optional connection to a PC, an external keyboard or a barcode scanner
- memory capacity: last 1000 measurements
