Stryker - 1015
by Stryker
Stretcher
The Stryker 1015 Stretcher is perfect for fast and efficient patient transfer while being economically friendly. The Stryker 1015 Stretcher is perfect for fast and efficient patient transfer while being economically friendly. The 1015 stretcher offers great versatility through its solid features integrated into its design for general use purposes. Extraordinarily mobile and user-friendly, the Stryker 1015 Series stretchers are designed to greatly reduce the physical strain on clinicians, while enhancing patient care and comfort. Advanced mobility options such as the centre Big Wheel make transporting heavy patients easy.  Fully equipped and highly configurable, the Stryker 1015 Series allows you to create the ideal solution to meet your specific needs.
FORUMSView All (3)
-corros
Fri Dec 23 2022
Can I have Service manual
How can I get 1015 stryker service manual
Equipment: Stryker - 1015
-RZamudio
Fri Dec 09 2022
Hydraulic Servicing
Are the fluid levels able to be replenished in the hydraulic pistons? I cant find anything in the manual other than "check if they are sufficient". In this case, a fitting was loose and allowed for fluid leakage and the piston will not raise to full height.Reply
3
-mikenike
Wed Sep 01 2021
Anyone have any tips/tricks for separating the hydraulic from the top bar? It always gets press-fitted over time and is a beast to separate .Reply
  • 3″ (8 cm) vinyl mattress on 26″ (66 cm) litter
  • 8″ (20 cm) Omni Surface™ casters
  • Fold-down side rails on 26″ (66 cm) litter (fold to foot)
  • Fold-down side rails on 30″ (76 cm) litter (fold to head)
  • Four IV receptacles
  • Central-locking brake system with dual-end activators
  • Integrated storage tray with oxygen bottle holder
  • Retractable fifth-wheel steering
  • Roller bumpers
  • Stationary foot-end litter
  • Dual cylinder pneumatic backrest
  • Dual pedestal hydraulics
  • Dual side-mounted foot control hydraulics
  • Hands-free Trend.
  • Wheel covers
  • Overall Length    83" (211 cm)
  • Overall Width    34" (76 cm)
  • Weight Capacity    700 lbs (228 kg)
  • Height Range    High 34" (91 cm)
  • Low 21" (55 cm)
  • Litter Positioning
  • Backrest    0°- 90°
  • Trend./Reverse Trend.    ±18° ±18°
  • Knee Gatch    0°- 30°
  • Patient Surface    26" x 75.5" (66 x 192 cm)
  • Siderails    13" x 55" (33 x 140 cm)
  • Caster Diameter    8" (20 cm)
  • Stryker Part Number    1015
